Mene pa zanima, ?e je kdo ?e opazil, da se mu tole izvaja. Gre za FL ?estko, dizelca. V manualu pi?e:
Injection Amount Learning Function
• The injection amount learning function has been modified. As a result, the PCM carries
out the injection amount learning function every 150 km within the first 1,500 km and
after that every 3,000 km, when all of the following conditions are met:
? Engine is idling
? Shift lever is in Neutral position
? Vehicle speed is 0 km/h
? Engine coolant temperature is between 65…95 °C
? A/C is not operating
? Accelerator pedal is not depressed
? DPF regeneration is not performed
• If any of these conditions change while carrying out the injection amount learning
function, the process will be suspended until the conditions are once again met. In
addition, the injection amount learning function has to be carried out at specified service
intervals (refer to the workshop manual).
Gre se za to, da mi spet malce cukne na AC ko se nekaj ?asa peljem s konstantnim gasom, potem ga pa narahlo pohodi?. To sicer ni prvi?, vedno pa to uredi za par 10.000 km, u?enje ?ob na testerju.
?e tole prav razumem, ima mazda vgrajeno avtomatsko u?enje, ki se izvaja ob zgoraj izpolnjenih pogojih, ampak nisem ?e opazi. Kaj naj, pustim laufat doma na ?tantgasu, pa da vidmo kaj bo :-)
  je SpEkTr napisal:
? Engine is idling
aha, jst to sli?im, dejansko se spreminja zvok motorja v leru, na mestu, po pribli?no 30 sekundah, ampak ne vedno.
Sweet :D
Se pravi na vsakih 3000km se tole aktivira, potem pa ?e so pogoji izpolnjeni se spro?i. ?e niso se ?aka na naslednji?. Bi bilo pa zanimivo zvedet, ?e je to res enako kot je se na WDSu naredi.
The PCM carries out injection amount learning every 1,500 km within the first 6,000 km of driving and every 10,000 km after that
  je SpEkTr napisal:
hm, ja sem prebral, o?itno ga ne razumem prav to?no, me moti beseda "every". Pa tudi, sem sli?im absolutno pogosteje to "u?enje :ne vem: "
Zanimivo. Tudi sam sem ?e ve?krat opazil nek ?uden zvok ?e je motor nekaj ?asa tekel na mestu, pa do sedaj nisem imel pojma kaj bi to bilo.
Ob?asno pa opazim tudi da motor malo cuka med vo?njo pri pospe?evanju in sicer nekje okrog 1800 -2200 vrtljajev. To se dogaja le ob?asno, zgleda se res ?obe potem same po?timajo. :blink:
  je johan napisal:
To?no to se meni dogaja. Zdej pa bogsigavedi kdaj bo pretekl tistih 10000km, da se u?enje spet aktivira :blink:
  je dpicul napisal:
Se pravi do 6000km se aktivira vsakih 1500km, potem pa na 10000. Skoda k ne mores vidt kolk se manjka do teh internih 10000. Mogo?e v kakem skritem meniju.
A sta med tem opazla kako pove?anje obratov?
  je SpEkTr napisal:
Ne, jaz nisem opazil spremembe v obratih, je pa o?itna sprememba v delovanju motorja, misli? da je kaj narobe :)
  je dpicul napisal:
To?no tako.
U?enje injektorjev lahko tud sam spro?i? roćno, brez kaker?nega koli ra?unalnika
Tule je opisano kako:
http://www.cdn.dk/mazda6/tips.htm
Pogoj je ta, da je ma?ina ogreta na delovno temperaturo.
Imam isti problem s tem cukanjem. Ko spro?im u?enje ?ob je potem za par tiso? kilometrov uredo.
Sem pa ?e opazil, da se mi cukanje najbolj pojavi, ?e mam notri Petrolovo nafto. Pri OMV skor ni cukanja.
  je Patric napisal:
Patric, kje je ta konektor? Na tej sliki na spodnjem linku (?isto spodaj) je to nekje na commonrailu?
https://euroesi.mazda.co.jp/esicont/eu_eng/...10f1800600.html
Sem slisal od nasega mazdasa da ga je to ucenje precej drago stalo (res da na 2.2 masini....)
  je jures napisal:
Kaj pa je blo?
Sicer pa, naj nekdo pove ?e mu je tole uspelo na FL ?estki.
  je SpEkTr napisal:
To smo ?e govorili se mi zdi, da to velja za cd140 motor ne za 143 verzijo s prej?nje ?estke.
je pa verjetno tole res samo za 140 CD, niti nise bil pozoren za katero mazdo se gre :vskalo:
Zgleda bo treba probat, tip na mazda6club forumu pravi da tut na prejsnji verziji to prime. Se prav eno ?ico, pa notr v konektor, en konc pa na ?asijo :notworth:
Sem probal za hec ?e enkrat, pa mi po petih minutah nekako ni uspelo. Zdej pa nevem, ali si ECU zapomni, kdaj si nazadnje to po?el oz. pri katerih kilometrih in ne omogo?a dokler ne naredi? spet xy km.
Ali pa je bila masa od kabla slaba. :) Sej ne vem, kam bi dal na maso, zadnji? sem na en ?rauf, v?eraj tudi pa ni prijelo. :)
