Hudi avti in fotke nasploh
Ker nimamo nobene teme kamor bi limali ?e kaj drugega kot izklju?no Mazde. Konec koncev vsi pogledamo ?e kako drugo znamko.
220 km/h+ na polno ?ez te ovinke. :hudicek:
Stare legende na kupu. Najbr? dost pijejo? :zvizga:
Neki za Markota:
Uffff :D Me like like
Tole je pa najbli?je kar bomo pri?li do vo?nje reaktivca po cesti :bravo:
Stelvio pa?e tukaj - to mam ?e letos v planu
Men ful v?e?en prednji konec Selike T23 (videna na avto.net)! :ljubezen:
Nwm ali je hudo :D
Tole mislim da je od Natke Ger?ina! :bravo:
Ne vem... Slikal sem ga na "Dolski" v Dolu pri Hrastniku... :harhar:
Bil ?e 3x toooook lepo. Kar ?veu bi tam.
Your future depends on it.
Your LIFE… depends on it.
A Klokateer...
Kaj je tu ?udnega? :hudicek:
Manjkajo najmanj 4je cilindri. :hudicek:
pa modre barve je :P
suspension test
tole je pa kar ?lanek treba
http://www.bestourism.com/items/di/7670?ti...orway&b=326
Tudi Romunija ponuja veliko
Pri Renault Sport so se odlo?ili, da bodo spet prodajali ekskluzivo, Clia RS Angels & Demons. Avto bo na voljo od no?i ?arovnic naprej v omejeni seriji 666 primerkov. :hudicek:
Data for the main engine functions in seven parameters including turbo pressure, oil temperature and brakes plus real-time engine performance data (torque, power)
Transverse and longitudinal g-force
Lap timer, with memory function
Acceleration times
The Renaultsport Monitor also enables the driver to modify the throttle pedal mapping. With the 'Sport' mode selected there is a choice of five settings (linear, normal, snow, sport and extreme) to adapt the car's acceleration characteristics to the conditions or to the driver's demands. In addition, the gap between the up-shift warning bleep and the rev-limiter can be adjusted in 50rpm increments from zero to 2000rpm.
The Renaultsport Monitor can be controlled by the satellite on the steering column. Once in use, the radio controls are over-ridden.
Je pa zadeva na itunes na voljo tudi za iphone, samo za informacijo.
No gremo k Angelem in Demonom. Eroti?na ?tevilka. :P
Gre za nekatere vizualne razlike.
Poleg tega bo imel 203 konje, torej spet 2 konja ve? kot zdaj?nja verzija, o?itno so spet ?arili okoli nastavitev.
In ?e glavna fotka zaradi katere sem objavil to novico tule. :hudicek: Pustimo photoshop u?inke, poglejte okolico.
Jebemti?, ?e bo ?lo takole naprej bom jaz ?e kar lep ?as na Renaultih ostal, ?e bojo le finance dopu??ale. B)
Lahko pa razume? tudi druga?e; da jih je po na?ih razrukanih cestah ?e zdaj preve? in so iz tega razloga tak?ne! :P :ne vem: :hudicek:
No, tale pa direkt pa?e v temo "Hudi avti" - http://www.jeep.com/en/srt8/
"6.4L HEMI? V8 engine delivers an estimated 470 horsepower and 465 pound-feet of torque"
Sicer ga verjetn ne bi rabil kot terenca :D (4.8s do 100km/h)
20" feltne, not pa 15" diski! :bravo:
Galardo pa ja ni mrcina :P
Takole bi se pa dalo po mestu "crusat" :P
?e tm ne dela pa tle zih
kaj mu to neki poka iz avspuha............zjeban motor :) ????
