Nov Mazdin bencinski motor - Skyactive-X
Je bolje... :prstgor:
Na?el tudi zapis o ?tevcih:
Inside, almost everything is new. Save for the steering wheel and a few obscure trim pieces, Mazda redesigned the cabin to chase more premium aspirations. Designers stretched the dashboard for a wider feel. And here we come to the 2018 6's next major update: the Signature trim. Mazda first rolled out the Signature trim with the new CX-9 crossover and the trim's intentions transfer to the 6. For the 6 sedan, well-crafted materials are awash throughout the cabin. They include Japanese Sen wood, nappa leather, and synthetic suede on the door pockets, seats, and dashboard.
All Mazda 6 sedans benefit from redesigned front seats, which the brand said are wider and absorb more vibration. Available options include an 8.0-inch touchscreen display, a 7.0-inch digital reconfigurable gauge cluster, a windshield wiper de-icer, and a head-up display.
https://www.motorauthority.com/news/1114049_2018-mazda-6-chases-a-more-premium-path
Oblika nove trojke?
koncept KAI
koliko bodo novi modeli sledili je vpra?anje
Zal je tako, da potem, ko pride do serijske proizvodnje ti avti nimajo vec veliko skupnega s predstavljenimi koncepti ...
Ah, ?eprav sem ?e videl kai koncept te fotke nisem prepoznal, ko sem jo videl v nekem drugem kontekstu. Jutranja nezbranost ...
Vidim, da teli prototipi v zadnjih mesecih lepo kro?ijo po vseh celinah med avto novinarji.
Osebno mi je tale monta?a ?e najbolj zabavna.
  • 4 tedne kasneje...
Sem ravno naletel na ?lanek, da bodo dali "baje slab?e" torzijsko vzmetenje zadaj, kot v M2 in CX3 v novo Skyactive X M3. Se pravi ne bo ve? Zoom Zoom?
?koda da so ?li v to smer...me pa vseeno res zanima ?e bo sedaj ?e vedno ostala v vrhu glede vozne dinamike...
  • 11 mesecev kasneje...
Hmh, in kaj jim bo dizelca v USA ?e pa majo ?e benz tak poceni?
V EU pa bodo po mo?nosti ukinili dizla ker je kao strupen
2008 Mazda 6
2004 Mazda 3
V USA je dizel ca. 20 % dra?ji kot bencin, pa ?e dobi se ga recimo na vsaki deseti ?rpalki. Dvomim, da se jim bo vlo?ek, ki so ga imeli s homologacijo motorja za USA trg povrnil, saj ugibam, da avtov ne bodo prodali veliko. Poleg tega pa imajo v CX-5 od letos 2.5T motor z 250 konji (oz. 227 s slab?im 87 okt. bencinom). Zakaj bi potem nekdo pri zdravi pameti kupil dizla, sploh pri njigovih cenah goriva.
Ja saj ne razumem te avtoindustrijske odlo?itve.
Naftni lobi? Logicnega ni nic vec, zato je vse mozno...:)
Zato, da bo prikolco vlekel, duh... :hudicek:
Glede na to, koliko proizvajalcev je v zadnjih 25 letih eksperimentiralo s HCCI motorji, vsa ?ast, ?e ga bo mazda uspela spraviti v serijsko proizvodnjo. ?e posebej, ?e bere? o tem kak?ne pomanjkljivosti ima tovrstni motor:
Disadvantages:
- Achieving cold start capability.
- High heat release and pressure rise rates contribute to engine wear.
- Autoignition is difficult to control, unlike the ignition event in SI and diesel engines, which are controlled by spark plugs and in-cylinder fuel injectors, respectively.[6]
- HCCI engines have a small power range, constrained at low loads by lean flammability limits and high loads by in-cylinder pressure restrictions.[7]
- Carbon monoxide (CO) and hydrocarbon (HC) pre-catalyst emissions are higher than a typical spark ignition engine, caused by incomplete oxidation (due to the rapid combustion event and low in-cylinder temperatures) and trapped crevice gases, respectively
Vsekakor to ne bo motor, za katerega bi ?elel biti beta tester, bo vsekakor za po?akat 5 let, da se izka?e.
https://en.wikipedia.org/wiki/Homogeneous_charge_compression_ignition
Pa saj je enako kot za wankla...
Saj to sem ?e od vsega za?etka rekel ?e jim takoj ne rata odpravit klenkanje, bo to fail od motorja. Tak motor bo mogo?e z dr?al tolk kot wankel.
O?itno bo to novi za??itni znak Mazde (okvara motorja po 100kkm).
2008 Mazda 6
2004 Mazda 3
Dvomim...Mazda si ne sme dovoliti da naredi slab motor ...posebno ta novi x motor .
Upamo da jim uspe...saj so mojstri..lp
O?itno ima Mazda resne te?ave z SkyactiveX motorji. Mazde 3 z SkyactiveX motorjem letos zihr ne bo v ZDA naprodaj, ?e pride v EU, pomeni da bo EU poskusni zaj?ek.
Lahko sklepamo da si v ZDA ne upajo dati polizdelka, zaradi morebitnih to?b, ?e stvar ne bo laufala.
https://www.motor1.com/news/346378/mazda-skyactiv-x-engine-delay/amp/
2008 Mazda 6
2004 Mazda 3
