Ameriĉka mazda ima, a evropska?
HOW CAN I CONNECT TO THE IN-CAR WI-FI HOTSPOT?
To access the in-car WiFi, please verify the following information:
  1. The WiFi on your smartphone device is turned on.
  2. Your vehicle is running, or in accessory mode.
  3. You have found the vehicle WiFi network name (ex: MazdaWiFi) and found your network password on the vehicle center screen:
  1. To find your Wi-Fi network name on the vehicle center screen:
    1. Select Settings from MENU
    2. Select Connectivity Settings
    3. Select Wi-Fi Settings
    4. Select SSID
    5. Find the Access Point Name (SSID) on your device, then select it
  2. To find your Wi-Fi network password on the vehicle center screen:
    4. Select Wi-Fi Password
    5. Enter the password on your device to connect to the Wi-Fi network
  3. Open a web browser on your device and you will automatically be redirected to the Wi-Fi trial sign-up page. Select the option to start your trial on that sign-up page
  4. Complete all the required fields and accept the terms of the Verizon customer agreement
You will then receive a confirmation email – it may take up to 15 minutes for the Wi-Fi to activate
    • Dobro, da nisem gledal... me je dopoldne nekaj spreletelo, da bodo pušnili. Pa vsi okol mene nahajpani in jim nisem želel kratit optimizma. Sem sam na hitro omenil, da se bojim, da bo tole kr konkreten poraz pa sem iz njihovih pogledov sklenil, da boljše da ne nadaljujem. Fak čist prevečkrat mam take flashe in pol se res zgodijo... ma kr samega sebe se bojim. 😳
    • Slovenska reprezentanca  je izgubila na gostovanju v Ljubljani. 😆 Domačini boljši 2:0. 🤣
    • Na spet sem za neki kriv pa ne vem zakaj.    A si kej vprašal?
    • @Slivka sem ti našel medij, kjer so ga lepo opisali in domnevno je levičar, ki želi umoriti domnevnega velikega vodjo... tko da domnevno so podatki pravi, ker domnevno je ta medij v službi domnevne resnice... vsaj tko sami sebi pravijo. Attention Required! | Cloudflare NOVA24TV.SI
    • Čemu so namenjene trošarine? To nima veze s tvojim razumevanjem kaj je fer in kaj ni. Trošarine država uporablja, kot vse druge dajtva in davke za svoje delovanje. Jebat ga ne živimo v plemenski skupnosti pa še tam so verjetno ble neke dajatve. V tri četrt EU so trošarinske razlike v škodo benza še bistveno večje, pa čeprav tam ni nobenega Goloba. Ker večino transporta po cestah temelji na dizlu previsoke cene le tega dodatno poganjajjo inflacijo zato jih tudi s trošarinami držijo nižje pri dizlu kot pri benzu. Trošarine na benzu ne vplivajo skoraj nič na splošno inflacijo.   To, da bi ti samo zaradi večje energijske gostote bolj obdavčil dizel se ti je pa verjetno v naglici nehote zapisalo. Se pravi boljši izkoristek bi ti kaznoval z višjo ceno... mater to se pa še komunisti niso spomnili - uravnilovka press.
